Is it just me or does the Ative Topics button no longer work after the move of the forums?
I doesn’t work for me either.
I’m not sure if yours is the same issue, but I use the “view unread posts” link, and after the migration the forums thought I hadn’t read anything… I had to click the “Mark forums read” link on the main page and then things worked normally again. Maybe this will fix your issue too?
Tried the mark forums read button to no effect. Active Topics still does not seem to work.
Not sure what’s going on with the code. It seems to not want to run the correct query. Until I get it fixed use the “view new posts” option. (http://packrafting.org/forums/search.php?search_id=newposts)
For what it’s worth the button works fine at
http://www.seakayakforum.com/search.php?search_id=active_topics&sid=e9527cdbfcfea496a058e873254e0532
and
that appear to be the same software, well they look the same (I know nuthing).
