I want to add some attachment points to my Yak, but the glued on spray deck is not centered (by design I’m told), and I’m not sure exactly where to locate them. I have 4 Tie Downs and 4 Strap plates, and I’m thinking of putting 2 of each (total of 4) on each side tubes, i.e. 2 tie-downs and 2 strap plates on each side (total of 8). The additional tie-downs are to create a "rail that goes all the way around the raft, and the tie-downs would be for fishing rod, paddle, what-have-you…
Now that I’ve painted that somewhat confusing picture let me get to my primary consideration… Is it OK to glue them in a position that overlaps the edge of the spray skirt and the raft tube in order to achieve a more balanced ballast… If I glue them where they are attached to the raft tube only they will sit on the side of the tube rather than the top.
